Salta al contenuto principale
La seconda generazione è stata introdotta come modello 2003 al Chicago Auto Show del 2002; basata sulla nuova piattaforma Impreza, presentava diversi miglioramenti rispetto al modello precedente.
How do I replace the map light?
One map light is no longer working and it needs to be replaced. I cannot find a way to disconnect and then replace. I have a 2007 Forester SUBN
Questa è una buona domanda?
Punteggio 2
2 Commenti
I can't believe how simple this was. If I had looked in the "maintenance" section of the handbook I would have found it. I looked in the internal lights/ map lights section that basically describes how everything works not how it is repaired. Thank you ! I honestly didn't think I would get an answer. This site is great.
da Condividi
please send me photo of the lght and I will explain to you how to replace it
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Hi,
Here is an image, taken from the 2007 Subaru Forester Owner Manual that shows how to remove the map light lens so that the bulb can be replaced. Scroll to p.11-48
Immagine
(Click on image to enlarge for better viewing)
1. Remove the lens by prying the edge of the lens with a flat-head screwdriver.
2. Pull the bulb out of the socket. Install a new bulb.
3. Reinstall the lens.
The map light bulb is 12V-8W
Punteggio 3
Aggiungi la tua risposta
Bonnie Jorgensen sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 39
Tutti i Tempi: 4,821
