Salta al contenuto principale
Rilasciato nel 2012, questo portatile presenta un processore Core i7, una GPU dedicata Nvidia 620M e un display 1080p.
fan working too much
Hello,
I bought some days ago a zenbook ux510ux , it is a nice device, it works fine, but i m afraid something is wrong with the fan, it is working almost all the time, even if I do nothing or just whaching on youtube etc. ,I need to know if is it actually a problem. It is really annoying sometimes.
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @drvip ,
Check that the fan exhaust vent on the side of the laptop is clear and unobstructed.
Use a vacuum cleaner on low suction to clear vent if blocked.
If it not blocked or the fan still runs all the time after the vent has been cleared, open Task Manager (right click on taskbar and select it) and see how many processes are running etc. The CPU may be doing a lot of things (maybe too many), in the background. What OS is installed in the laptop?
If that looks OK then you may have to disassemble the laptop and clean the fan and maybe apply new thermal paste to the CPU and see if that helps at all.
Here is a link to the ifixit Asus Zenbook UX32VD repair guides, which should be of some help.
Punteggio 3
Aggiungi la tua risposta
vladimirposmag sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 1,484
