Salta al contenuto principale
Informazioni sulla riparazione della stampante fotografica a getto d'inchiostro a colori Canon PIXMA iP4700. Rilasciata nel 2010. Numero di modello: iP4700.
My printer is having problems Printing.
My ip4700 is printing very faint lines or not at all. This is mostly the black print but the colors are having similar issues.
I did a nozzle check and it was perfect. Everything printed fine. The instructions say not to do a cleaning if the nozzle check is okay.
Any ideas? Thanks.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi @dreemsnake ,
What happens if you copy or scan a document using the printer's control panel, does it print OK?
If it does and you are only having problems when printing from a computer, what OS is installed in the computer and how is it connected to the printer, wireless or cable?
da
Aggiungi un commento
1 Risposta
I would suggest running a cleaning a couple times, and if that doesn't resolve the issue, try replacing the ink cartridges.
Punteggio 0
Aggiungi la tua risposta
lori sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 23
Tutti i Tempi: 812
