Salta al contenuto principale
Il Motorola Moto G (2a generazione), conosciuto anche come Moto G2, è il successore del 2014 del Moto G. Il Moto G2 è dotato di un display da 5 pollici 720p e di un processore Qualcomm Snapdragon 400. Numeri di modello XT1045, XT1040, XT1039, XT1069, XT1068 e XT1064.
Why is the touchscreen unresponsive for a while?
Hi. I have this weird problem with my phone. When I turn off the screen/lock it, if I turn it on inmediately or after a bit the touchscreen won't work. It won't respond to my pressing and I have to leave it there for a while.
After a period of unresponsiveness (which can range from about 15 seconds to several minutes) the touchscreen will start working normally, until I lock the phone again and it does the same thing. Every time. Sometimes I can hear the "locking" sound a while after I pressed the "lock" button, which suggests that the problem is that the screen enters a long "locking" period rather than doing it instantly as it should when I press the button.
I've had this phone for a couple of years, and this problem started some time after I had to do a factory reset because it had entered an endless loop of turning itself on and off. So I don't know if this is a software issue or a hardware one, and in either case, I have no idea how to solve it. For that reason I'm asking here before trying another factory reset, since I don't know if that'll solve anything.
Can anyone help?
Questa è una buona domanda?
Punteggio 0
1 Commento
Sorry, I should have clarified that I tried restarting the phone and it doesn't work.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @dreadjaws ,
Back up the phone using the phone's backup feature.
Fully charge the battery.
Perform a hard reset (or factory restore as it is also called) using the phone's factory restore feature.
Be aware that a hard reset will erase all your data and downloaded apps. It will be like when you first bought it. That is why it is important to do a backup first
Once the phone has been reset, test the digitizer (touchscreen) function to see if it operates correctly.
If it still does not operate correctly then you have a hardware problem.
If it operates correctly (allow a bit of testing time to ensure that you are satisfied that it is working OK) then restore the phone from the backup you made earlier using the phone's restore feature.
Once the phone has been restored to its' previous state test the digitizer function again.
If it operates correctly (again allow a bit of testing time to ensure that you are satisfied that it is working OK) then the reset has resolved the problem.
If it does not operate correctly once again, then a downloaded app may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and test the digitizer function, between each uninstall until it operates correctly. Once it does work correctly the last app that you uninstalled will be the culprit.
Update (12/15/2017)
Hi @dreadjaws ,
At least you now know what the problem is.
Here is a link to the ifixit Sostituzione dello schermo LCD del Motorola Moto G 2nd Generation guide
Here is a link to just one supplier of the replacement part -LCD screen + digitizer. It is not a recommendation to use them. It is shown to give an idea of the cost. There are others online that may suit you better. Just search for Moto G 2nd Gen LCD screen/digitizer part
Punteggio 3
1 Commento:
Well, I followed your procedure and it does appear to be a hardware problem. In fact, the touchscreen has stopped responding completely, even after a couple of hours of letting it untouched. I guess an easy solution was not in the cards. :( Thanks, anyway
da
Aggiungi la tua risposta
Pablo Rodriguez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 29
Tutti i Tempi: 8,538
