Salta al contenuto principale
Il Sony Xperia M2 è uno smartphone Android 4G di fascia media prodotto da Sony Mobile. Disponibile da maggio 2014.
Not Charging : Dead
Hi Team,
Sony Xperia M2 - Dead Unit.
Device status & measurements :
The fault is Phone is not charging, USB Power ( 5V, 10-20 mA) Battery Charging voltage 1.1 - 4.1V, current fluctuating.
Note : This is liquid damaged device
Observations & tests
  • TH voltage is 1.2V it seems OK
  • There is no BAT EN signal 0.6V
* Phone can be power on when given the BAT+ - to with external power supply
  • When plug the battery connector 0V at battery terminals. that's mean Battery Disable itself
  • When unplug the battery and can be get measurement 3.7V
  • Checked with new battery, same result observed. - Battery is OK
If any idea please comment. Thank you for your time. in simple i need to enable BAT EN signal or need a way to bypass. or Please help to find schematic diagram for D2303
Questa è una buona domanda?
Punteggio 2
1 Commento
Buddhika Mahesh this is going to be tough. There are no more schematics available since Sony does not repair any electrical components anymore.
da
Aggiungi un commento
1 Risposta
Risposta più utile
Buddhika Mahesh the only thing you could try is to hack it together like this
Immagine
from here
Punteggio 2
2 Commenti:
Already checked the path. 2-3 Ohms. 4.9V there. i need to generate anyhow BAT_EN signal. otherwise have to replace PM IC.
oldturkey - As always, Thank you for helping us! :-)
da
Buddika mahesh im from sri lanka is there a way to contact u
da
Aggiungi la tua risposta
Buddhika Mahesh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 32
Tutti i Tempi: 3,234
