Salta al contenuto principale
Informazioni e guide di riparazione per l'iPhone 6s rilasciato da Apple il 25 settembre 2015. Modelli: A1688, A1633
No one found solution to my problem!
It's over 2 month since last time my wifi worked. All started after i dropped my iphone when i was away from home. Came back i tried to connect to wifi but i couln't. So i restored. Nothing. Still the same. Wifi greyed out, Bluetooth searching circle. Mac adress N/D.
Had same problem of this guy.
Wifi / bluetooth greyed out iPhone 6
I actually changed my antennas. Nothing, still the same.
I changed the Wifi IC Chip on the motherboard with a friend who's very good at electronics. Iphone turned on. Problem still the same. Can someone troubleshoot if we make mistake on putting back the wifi module on the motherboard?
If is like this, why the phone still turned on? Please help me out.. i don't want to bring it at local chinese store that want to charge me 150 euro. I changed everything of my iphone.
Screen x3 Times
Battery x2 Times
Charging port x1 Time
Camera module x1 Time
External Shell x2 time (nice colored ones :) )
If i will succesfully solve my problem, i'm gonna give 5 dollars to the guy who helped me successfully. Why? Spent:
15 euros on wifi module
12 euros on antennas
(Here in italy everything it's expensive i know. In america i could pay them few dollars.)
I don't have anything to lose, just using my 1GBxDay data plan. But i can't continue watch my netflix series from phone and youtube videos as well. And very ofter i arrive at half day without internet and without the possibility to connect to an Wifi.
Questa è una buona domanda?
Punteggio 0
1 Commento
I will check! I will let you know. We'll verify everything of the phone!
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Greyed out Wifi is most likely the IC...or one of the components surrounding the IC on that circuit. I would start by looking at the schematic and testing each one to see if there's a short or bad part that needs replaced.
It is a difficult repair, even for an experienced tech...I don't knkow the skill level of your friend or the tools available...I know your friend may have experience in electronics, but possible that a mistake was made or the New IC was bad.
Put it under a scope, make sure nothing is knocked out of place, test for shorts, voltages, etc...
It's a hard one to diagnose through text but my $ is on the IC
Punteggio 4
Aggiungi la tua risposta
Alin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 8
Tutti i Tempi: 196
