Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
Memory upgrade to 32GB
I am wondering if the MacBook Pro 15" Retina Display Mid 2015 memory can be upgraded to 32GB.
Questa è una buona domanda?
Punteggio 10
1 Commento
Bei Aliexpress gibt es RAM Bausteine in Sets zu kaufen (sk hynix H5ANAG8NAMA) Mac Accessories Store - eine Anleitung diese zu verlöten gibt es auf YouTube -
iBoff RCC
https://www.youtube.com/watch?v=e-acbB0d...
Header / Title: "16GB to 32GB Soldered RAM Upgrade - 2018 MacBook Pro 15-inch - 4K
googln: z.B.: "Memory Chip IC Für Macbook Air Pro"
"Reparatur Ram Flash"
"Flash, RAM und Co.: Speicher für Industrie und Automobil - Halbleiter - Elektroniknet"
Preisgünstiger könnte sein bei älteren Modellen ein gebrauchtes Mainboard Hauptplatine Logic Board zu kaufen. Für das Auslöten und Einlöten muss sowieso das Board ausgebaut werden.
Nachhaltig ist Apple mit der Schiene nicht! und mit dem Kabelbruch Problem am Display von 2016 bis 2019 - auch nicht gerade schnell am Reagieren.
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
None of the 2015 MacBook Pro laptops support this much RAM. Only a desktop system is able to and only a few models have the ability to be upgraded to this level.
Presently all of the retina series have soldered RAM only the older non-retina series has upgradable RAM.
The newest touch bar retina series systems also have soldered flash storage so they can’t be upgraded but the older retina series have socketed flash SSD drives.
Update (10/31/2019)
Apple now offers 32 GB of RAM as a special order config in the 2018 & 2019 15” MacBook Pro Touch Bar systems. This is soldered in RAM!
Punteggio 26
According to Wikipedia, MacBook Pro Retina has soldered on RAM, the Unibody before it has upgradeable RAM slots, you may upgrade those up 8gb per slot = 16gb max.
Punteggio 2
1 Commento:
I understood it that you can only upgrade before purchase on models after 2015
da
On this model you can ONLY upgrade the SSD, unfortunately you CANNOT upgrade or downgrade on RAM, you're stuck with what you got when purchased.
Punteggio 2
iBoff RCC
Punteggio 0
1 Commento:
IBoff RRC - Does this as a customization, it’s still quite experimental! And once done it will be hard to recoup the expense for many.
The amount of time saved is seconds even with large work pieces. I was producing ultra large photos for stage and exhibits. I wasn’t saving that much with more RAM, I saved more with larger and deeper storage. In my case my work drive is a NVMe RAID box with five 4TB drives. And my boot/OS drive is a 2TB internal with just 16GB of RAM on my 2015 15” and my 2013 Mac Pro which has 32GB is only slightly faster which I contribute as it’s a faster CPU.
da
El diseñador gráfico Alejandro Federico tiene este macbok pro, y no es posible amentar la ram de este ordenador el maximo son 16 GB
Punteggio 0
Aggiungi la tua risposta
Rodgers Chishiba sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 100
Tutti i Tempi: 73,786
