Salta al contenuto principale
Netbook del 2008; Modello ZG5 AOA150-1691; schermo da 8,5"; processore Intel Atom N270 da 1,6 GHz
No bootable device available
It says to insert disc and press a key it says
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @mmm813 , proceed to your acer bios, and check if the hard drive is detected.
Under the BIOS you should see if the HDD is detect,
If so, run HDD diagnostic test to check on your HDD.
Some BIOS has a built in simple HDD test, you can check from there.
else, your HDD could be faulty. the only way to test is to get a known working one to replace and see if the system detects it.
If your hdd has issues and wish to replace, I would recommend you to replace to a SSD for performance.
Punteggio 2
1 Commento:
try but i didnot work
da
Aggiungi la tua risposta
Melissa sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 13
Tutti i Tempi: 3,560
