Salta al contenuto principale
Un disco rigido esterno con interfacce USB 2.0 e FireWire 400/800. Disponibile con capacità comprese tra 320 GB e 2 TB.
How do I replace the enclosure
I have a studio passbook and the hard disk is spinning, but it appears my enclosure needs to be replaced. How do I do this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi, what issues are you facing?
I think the internal height HDD is bigger than the usual 2.5 Inch drives.
So you dun have much choices to get a 3rd party enclosure.
Either you need to get from donor parts from ebay to replace.
I had read and heard some WD external drives need specially their boards for the drives to works, so it would be good for you to keep your old board, just in case.
Punteggio 1
Aggiungi la tua risposta
Kyle “DJ XCEL” Rodriguez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 39
Tutti i Tempi: 2,179
