Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento:
@hairs,Montell, More info. may give a better answer, what exactly happen, did the drive shaft break, did the transmission pop out of gear, did the transmission start slipping and you lost all gears? Help us to answer your question by being a little more descriptive. If it was your drive shaft that broke and fell off, normally caused by a faulty/dry(no lube),bad universal joint or loose/broken universal retainer/bolts.
da L Pfaff
