Salta al contenuto principale
Motore per tosaerba Briggs & Stratton 190cc Modello 120000 Quantum 675 Series. Rilasciato a febbraio 2011. Per tosaerba con coppia da 6,75 ft-lb.
Were is the primer button?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
@beverly27, Beverly, Not all engines have a primer, below I posted a link to BS Quantum series operators manual that may help in showing primer bulb, choke lever,etc., locations if equipped. Page 7 of the (2nd) link guide/ manual explain there are 3 different starting systems primer/choke/Ready start, you can look at the manual and find which system your engine uses and instructions will show how to operate. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://hurcotech.com/wp-content/uploads/...
http://www.northerntool.com/images/downl...
Punteggio 1
2 Commenti:
if this is craftsman gold series 6.75 hp you have no primer no manual choke and no throttle——these things are great!
da
How do I start it then? The craftsman
da
Aggiungi la tua risposta
Beverly sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 15
Tutti i Tempi: 10,411
