Salta al contenuto principale
L'HP Pavilion dv6500 è un notebook multimediale economico con uno schermo da 15,4", un case elegante e uno scanner di impronte digitali per la sicurezza.
Why does my screen not displaying
It seems like the screen backlight is up but no display other than the blank dark screen....
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta più utile
This problem can be either the laptop display or the GPU/motherboard. You can test the GPU by connecting an external monitor, if the monitor displays then the problem is in the laptop display. The laptop display could have a problem with the back light, if you shine a bright light onto the display and you can see icons on the desktop then the problem is the back light. If all you see is blank then the problem is the laptop display.
Punteggio 3
2 Commenti:
Thanks for your answer but I have tried using another monitor but still no display...
da
The problem is the GPU on the mother board.
da
HP laptops are tops soldered at the factory, meaning they are baked.
A temporary fix if it dies on the road is using a hair dryer.
The permanent fix is by rebaking it.
https://www.youtube.com/watch?v=G65-ncBx...
Punteggio 1
1 Commento:
Thank's to Michael Otero for his video.
da
You can also try this for a reflow procedure.
http://www.deskdecode.com/how-to-fix-a-l...
Punteggio 0
You can use reflow to fix ANY top soldered board including automotive and television applications.
Punteggio 0
1 Commento:
Not always. Most of the time yes, but there are exceptions
da
Aggiungi la tua risposta
Nsikan Udotung sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 1,014
