Salta al contenuto principale
L'Asus Q501LA è dotato di un processore Intel Core i5 4200U (1,60 GHz).
laptop has burn component
hi there i have an issue with my laptop,there is a burned component near the LCD connector and near the battery connector hope someone can send me a clear picture of it so that i can replace it manually
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Can you send a picture of the burnt component? It would be easier to see the damage than to guess.
da
@haron09 post a couple of images of the component as well as where it is located on your board. Use this guide for that.
da
DrGlowire did you see the picture below
da
Aggiungi un commento
1 Risposta
hi DrGlowire here is the picture
Immagine
Punteggio 0
1 Commento:
by the way this motherboard is for ASUS Q501L hope someone can reply and solve this issue,i need that that component so that i can replace it thanks.
da
Aggiungi la tua risposta
haron medina sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 5
Tutti i Tempi: 462
