Salta al contenuto principale
Frullatore compatto prodotto da Homeland Housewares
Motor continues to run
The blender does not turn on easily. Then when the blender is removed the motor keeps running.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
rosalie, If blender under warranty return for replacement,repair/refund. It sounds like the bullet has an internal switch issue. Below I will post a link to show how to dissemble the blender so you can clean/check/replace switch if need be. If not wanting to work on the blender yourself take into a good local small electronics repair shop and have them take a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Smontaggio del Magic Bullet
Punteggio 0
Aggiungi la tua risposta
rosalie sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 7
Tutti i Tempi: 604
