Salta al contenuto principale
Tablet computer ad alte prestazioni rilasciato da Apple l'11 novembre 2015. Modello A1584.
Touch not working after screen replacement
Replaced the LCD o a customers iPad Pro 12.9, solder job all done well but there's no touch. The LCD comes but but won't respond to my touch. Could it be a bad screen ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Risposta più utile
Check to make sure all the connectors are fully inserted. It is possible it is a bad screen but make sure everything is firmly connected and the ports inside are dust free.
Punteggio 1
This problem mostly occur when tech connect LCD with battery connected and filter is blown 120Ohm 450mA near to Touch Connector.
Punteggio 1
Got word that I might have blown the "power touch line" without schematics I don't know what to do :(
Punteggio 0
If you didn't disconnect the battery while fitting the screen you have burnt out the touch filter unfortunately you need a multimeter and check for continuity
Punteggio 0
Aggiungi la tua risposta
Jesse sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 11
Tutti i Tempi: 3,044
