Salta al contenuto principale
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
Touch not working after screen replacement
Replaced the LCD o a customers iPad Pro 12.9, solder job all done well but there's no touch. The LCD comes but but won't respond to my touch. Could it be a bad screen ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Risposta Più Utile
Check to make sure all the connectors are fully inserted. It is possible it is a bad screen but make sure everything is firmly connected and the ports inside are dust free.
Punteggio 1
This problem mostly occur when tech connect LCD with battery connected and filter is blown 120Ohm 450mA near to Touch Connector.
Punteggio 1
Got word that I might have blown the "power touch line" without schematics I don't know what to do :(
Punteggio 0
If you didn't disconnect the battery while fitting the screen you have burnt out the touch filter unfortunately you need a multimeter and check for continuity
Punteggio 0
Aggiungi la tua risposta
Jesse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,821
