Salta al contenuto principale
Il telaio W123 copre le 240D, 300D, 300TD, 280E e molti altri modelli di coupé, berline e station wagon Mercedes prodotti dal 1977 al 1985.
fuel gauge erratic behavior
Occasionally my fuel gauge jumps left to right and right to left, then resets to correct position.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
@lollygirl, David , Check the wiring/plug by the tank to see if loose/dirty/corroded and if able to check ground wire and loosen and retighten to make good connection, if all looks good the in tank fuel sending unit may be faulty or a bad actuator at the fuel gauge on your dash. . See links below for more info and trouble shooting ideas. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://mercedessource.com/problems/elec...
http://www.benzworld.org/forums/w126-s-s...
Sostituzione sensore livello carburante Mercedes W123
Punteggio 3
1 Commento:
How would I know if my fuel gauge actuator is bad? I noticed that the needle was moving as I moved my sending unit float back and forth.
da
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 4
Ultimi 30 giorni: 18
Tutti i Tempi: 3,998
