Salta al contenuto principale
L'Asus ZenPad S8 è un tablet Android da 8 pollici prodotto da Asus. Rilasciato nel giugno del 2015. Numero di modello: Z580CA.
Water damage please help
My two year old pee'd on it is there any chance i could repair it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@cainz, Cainz , Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the tablet from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the tablet to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the tablet and see if further damage has to be addressed. Good luck.
Smontaggio di ASUS ZenPad S8
Electronics Water Damage
Punteggio 2
Aggiungi la tua risposta
Cainz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 16
Tutti i Tempi: 507
