Salta al contenuto principale
Modello M6497 o A1005 / processore G3 da 500, 600, 700, 800 o 900 MHz
Very dark screen iBook g3
I have read many have "black screen" due to logic board issues but i can see my screen faintly, not enough to use. it does work with external monitor very well. seems like the issue is power to the backlight but former owner said he replaced the backlight, inverter board and display. does the fact that i can see faint images mean the logic board is not the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Your problem is probably with the backlight-inverter LCD or the cables connecting them. Since the previous owner replaced most of these items I would first check the cables are all properly connected and in good condition and then consider replacements.
Punteggio 3
Aggiungi la tua risposta
jellero sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 25
Tutti i Tempi: 1,152
