Salta al contenuto principale
Il LeapFrog LeapPad Platinum 31565 unisce uno schermo touch screen multi-touch ad alta risoluzione da 7'' a un potente processore quad-core. È il modello più recente della linea di tablet didattici di LeapFrog.
How do I replace the charging port?
How do I replace the charging port? My child unplugged it incorrectly too many times. Now it doesn't work.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
The USB charge port has probably come loose off the motherboard or is damaged in some way. Since it is a SMD (Surface Mounted Device) type USB connector, you will need the requisite SMD soldering skills and tools to either solder the old connector back onto the board or to un-solder the old connector and then solder a replacement connector onto the board if the old connector is found to be faulty.
This is not a job for novices. You can cause more problems than what you had before you started if you don't know what you are doing.
Here is an image taken from the Ifixit repair guide for the motherboard replacement of the tablet, showing the location of the USB port (red arrow) on the motherboard.
Immagine
(click on image to enlarge for better viewing).
I recommend that you contact a reputable, professional mobile phone repair service or an electronics repair service and ask for a quote to repair the tablet.
Punteggio 5
Aggiungi la tua risposta
sara22878 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 4
Ultimi 30 giorni: 16
Tutti i Tempi: 7,951
