Salta al contenuto principale
La Sharp EL-531X è una calcolatrice scientifica prodotta da Sharp.
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Questa è una buona domanda?
Punteggio 2
1 Commento
The calculator will display 1 no matter with the battery or not.
It stop working.
da Condividi
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Immagine
Reset
Immagine
(click on images to enlarge for better viewing)
Punteggio 2
1 Commento:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
da Condividi
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Punteggio 0
Aggiungi la tua risposta
fahimakhan2 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 51
Tutti i Tempi: 5,339
