Salta al contenuto principale
Rilasciato nell'aprile 2015, conosciuto anche con il nome di modello A10-70F ('F' indica che si tratta di un modello solo Wi-Fi).
Lost connection to apps
I first noticed when I couldn't connect to Play store for updates. I've checked and reset my WiFi connection several times. Odd that I get email but can't access Pandora and others.
Questa è una buona domanda?
Punteggio 0
1 Commento
Phone needs updating
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi,
Try the following:
1. Check that the date and time on the tablet is correct.
2. Try updating the Play Store app.
Punteggio 2
2 Commenti:
The time and date were correct but I still can't connect to the play store, Pandora, google play and others. Odd because I can get my Gmail without a problem. I just tried to factory reset and it doesn't respond. Now I don't have a clue about what to do.
da
Hi,
What doesn't respond, the tablet or just certain apps? If it is the tablet and I assume you mean that it doesn't start properly etc, ensure that the battery is fully charged, remove the external SD Card (if any installed) and then try a factory reset again using the Power/Volume button method. Don't leave the charger connected when you do this.
Here is a link that shows how to do it. Use the 1st method shown (obviously)
http://www.hardreset.info/devices/lenovo...
da
Feb 25 at 10:33 PM
Thanks, the hard reset worked. It was booting up like it should, but some apps wouldn't open, Pandora, YouTube, Photos.... Amazon Prime app worked though. I noticed that my gmail acct wasn't updating and I couldn't delete it either. I checked a lot of other settings too before deciding to factory reset, but nothing helped.
I had tried two soft resets with no results and when I tried the factory reset in settings it didn't respond at all.
The hard reset worked well even though I tried to bypass the auto backup that Lenovo has so it downloaded all the apps and files that it backed up.
It's now working again, thanks
Thanks again for your help.
Dave
Punteggio 0
Aggiungi la tua risposta
shafterdcw7 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 784
