Salta al contenuto principale
Rilasciata a maggio del 2012 e identificata con il numero di modello CE657A#BGJ, la HP LaserJet P1102w è dotata di connettività USB e Wi-Fi.
Why does it not print correctly
Hello. I have an HP Laserjet P1102w that prints clearly but whenever it prints the prints comes out in a slant way. I seem not to understand whats going on with the printer. I have cleaned the head and changed the toner but its the same result. I'm hoping I ll be able to find an answer here.
Questa è una buona domanda?
Punteggio 1
1 Commento:
Hi, Not trying to be smart, but have you checked that you are not printing whatever font you are using in "italics"?
da
Aggiungi un commento
1 Risposta
I have several clients that have the same printer… usual fix is totally delete the printer. remove the USB cable, reboot and then see if the printer still shows. if yes again do a uninstall and remove from device & Printers. so that when you reboot you have NO PRINTER… then shut off computer, plug in printer cable. start computer and follow any instructions. it should AUTO start to install Printer.
Punteggio 0
Aggiungi la tua risposta
shobenboy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 682
