Salta al contenuto principale
L'HP Pavilion dv2913cl è un computer portatile da 14,1 pollici che vanta un hardware apparentemente discreto per l'epoca. Il portatile presenta un logo HP sulla parte frontale del dispositivo ed è caratterizzato da una colorazione argento/nera.
Why is my computer screen not working?
Why is the lcd screen not working correctly? It will not work and there are no cracks.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi, Try connecting an external monitor to see if it displays a picture.
da
Aggiungi un commento
1 Risposta
Monitor is not on
Make sure the monitor is on. If you do not see a power LED (blue, green, or orange light) on the front of the monitor, press the power button until it comes on. If no light comes on after several attempts, make sure the connections are properly connected.
Computer is asleep
If your computer monitor was on and you stepped away from the computer, then upon returning, it was black, it is likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, or pressing any key (e.g. spacebar) on the keyboard to wake it up.
Connections not properly connected
Check the data cable
Make sure that you are connecting the monitor's VGA cable to the back of the computer in the 15-pin connector, as shown to the right, or the older computer 9-pin connection.
Note: Newer computers may be using a DVI or HDMI cable for the monitor. Make sure the data cable you are using is firmly connected to the computer.
Check the power cable
If the data cable is plugged in, make sure the monitor is getting power by verifying there is a light (blue, green, or orange) on the front of the monitor.
If you see no lights on the monitor, make sure it is connected to a working wall outlet. If the power cord is removable from the back of the monitor, try replacing it with another power cable. If you still cannot power on the monitor after trying another wall outlet and cable, the monitor is bad and should be replaced.
Check the LED status
If the monitor has a light on the front, but that status light is orange or flashing, make sure the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If this does not help, turn the computer and monitor off and reconnect the data cable on the back of the computer and, if removable, on the back of the monitor. Turn the computer and monitor back on. If you still encounter the same issue, continue reading through the other possibilities.
Monitor settings are not correct
Verify the brightness and contrast are turned up or adjust the brightness and contrast. If adjusting the brightness or contrast has no effect on the monitor, continue reading through the other possibilities.
Problem with the computer
If the computer was working when the screen went blank, the computer might have a problem. Try powering down the computer by pressing and holding the power button until the computer turns off. Once the computer is off, wait a few seconds and then try powering the computer on again.
No POST
Does the computer beep when it is turned on or does it sound like the computer is working? If the computer does not beep or beeps abnormally, the computer is experiencing a hardware issue or is exhibiting a No POST. Run through the POST troubleshooting steps to determine the failure.
Hardware Issue
If you have followed the above recommendations and still have the same issue, your computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the suggestions below.
Disconnect your monitor and connect it to another computer. For example, try connecting it to a friend or family's computer or a computer at a service center.
Borrow a computer monitor and connect it to your computer.
If your monitor works on another computer, it is safe to assume that the video card or potentially the motherboard in the computer is bad.
Troubleshooting a bad video card.
Troubleshooting a bad motherboard.
If another monitor works on your computer, it is safe to assume that your monitor is bad and should be replaced. While it may be possible to have the monitor serviced, it is often cheaper and easier to purchase a new monitor.
Punteggio 0
1 Commento:
Hi @raichel121 ,
Detailed answer but you may wish to check the type of equipment that the OP was asking about first before answering.
The device being asked about is a 'Laptop'. Unless mentioned as the problem there is no 'separate' monitor power cable, no external monitor data cable, no separate monitor full stop! Very hard to disconnect the screen without opening the laptop. Usually no separate video card in a laptop. The list goes on..
da
Aggiungi la tua risposta
Adam Braga sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 12
Tutti i Tempi: 365
