Salta al contenuto principale
Tablet da 8,9 pollici, sviluppato in collaborazione da Google e HTC. Rilasciato per la prima volta a novembre 2014, con sistema operativo Android 5.0 Lollipop.
The upper Speakers problem
Dear,ifixit team. Want to know my Nexus 9 tablet the dual front facing speakers only the downside one working which the upper upper one didn't make any sounds! Is it the speaker broken or the software problem?? Please help me out. Thanks and hope to hear from you soon.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Have you tried using earphones to check if there is audio in both L and R earphones?
If there is then most probably the internal speaker is faulty or has a loose connection.
Here is the Ifixit guide on how to access the speakers.
Sostituzione altoparlanti Nexus 9
If not then perhaps it is a earphone socket fault, a motherboard fault, a speaker fault etc.
In any event the tablet will need to be opened so that the problem can be further diagnosed and then repaired.
Hopefully this is of some help.
Punteggio 2
Aggiungi la tua risposta
Woon Ping Ng sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 12
Tutti i Tempi: 410
