Salta al contenuto principale
Il Google Pixel C è un tablet Android da 10,2 pollici rilasciato il 20 settembre 2015. Il dispositivo è realizzato per essere compatibile con una tastiera che si aggancia magneticamente e si connette tramite Bluetooth.
Display Problem Half display visible
Half of the display was not visible only half screen was working the touch is working completely whether i should replace lcd or lcd with touchscreen.
Questa è una buona domanda?
Punteggio 11
8 Commenti
Hi @atom13
How long have you had the tablet? It seems a very new model, therefore it still should be under warranty.
da Condividi
Hello@jayeff
Its still under warranty but i stay in india i bought it from USA there is no service centre for pixel c in india even i tried to contact customer service but they are saying we can't help you.
da Condividi
Only didn't start screwing up until month past warranty and we told to buy a new replacement out of my own pocket. I see more and more instances on this happening. Google screwed up this time and should recall effected units
da Condividi
My tablet started showing this within just a couple weeks of arrival. Its replacement took barely four days. My 2nd replacement is due in a couple days, and I'm not terribly hopeful that one will work any better.
da Condividi
The same thing happened to my tablet when just out of warranty. I can't get it repaired and Google doesn't want to know about it or help. I'll never again buy a Google product.
Joe
da Condividi
Mostra 3 altri commenti
Aggiungi un commento
7 Risposte
Soluzione prescelta
Hi @atom13 ,
If you purchased it from Google or an authorized reseller in the USA then the phone is covered by the Google International warranty.
Here is a link to the warranty which explains what the provisions are and what you have to do and what you can expect them to do.
A quick read is that if they accept your claim you will have to pay for the return of the product and they can supply at their discretion either a new or refurbished device
https://support.google.com/store/trouble...
Punteggio 3
2 Commenti:
I contacted google customer support bro but they said i should go and replace the device from the store where i bought it
da Condividi
Hi, I don't know if this is correct. Maybe you should ask them (HTC) if there is an International warranty offered by Google on their products.
http://www.gsmarena.com/htc_retail_store...
da Condividi
Risposta più utile
After replacing my Pixel C 4 times now (RMA, same issue) I finally ran out of my warranty time. All four had the same issue (split screen). This time I removed the LCD from the chassis, I found that the LCD embedded ribbon (meaning the glued ribbon on the rear of the LCD screen was partially torn/ripped (see attached photo). I believe this happens due to an engineering mistake. You see the embedded ribbon make a sharp 180 degree turn in a tight radius and spreads along the edge of the screen, distributing the image to the LCD. This tight radius turn of a very fragile ribbon makes it susceptible to being under pressure (wanting to return to its manufactured nature) this when the inside of the tablet gets hot and when the user consistently pressing in that area (i.e. game playing, etc.) the ribbon starts to fail and then rip. This IS an engineering screw up and is consistent with this symptom everyone is experiencing.
Note: the only way to repair this is to order a replacement screen ( since the ribbon is manufactured to the screen itself) …another engineering blunder.
-Eric A. - Digital Engineer/Technician
Punteggio 7
2 Commenti:
So what did you do?
da Condividi
Exactly, how do you fix the ribbon?
da Condividi
There are no screens left on the market for the pixel C, and so we are left with zero options but to figure it out the hard way. I was 100% successful… eventually. . My best advice is to get the screen off and the front camera detached. Then with a plastic spuger and the display on, flex the cable gently in a few spots to find where your problem spot is. When you flex the problem spot the display instantly turns off. I used six pieces of electrical tape stacked on top of one another holding the display ribbon to the rest of the device (NOT TO THE BACK OF THE DISPALY). No more half corrupt screen, no more issues. It took me 8 hours of trying and trying again with tape in different places to fix this- and I imagine it will be different for each of you. Anyway, my electrical tape is in red, below. It holds the ribbon to the rest of the device, NOT to the back of the display. Hope this helps!
Immagine
Punteggio 5
I took it to several shops, but no one was willing to work on it... in one case, because they had a service agreement for Google devices, and the Pixel C (along with the Pixelbook) were devices they were not allowed to do any hardware service for.
However, I have it working again, for now at least, after I took a look at the teardown and then pressed pretty hard on the screen at the place where the ribbon cable connects (center right). Here's hoping that fix lasts a while!
Punteggio 4
4 Commenti:
Thanks Sage Ross, that fixed it for me too, at least for now
da Condividi
Thanks Sage Ross, This fixed my problem too.. Hoping it stays this way for a while. But my screen is a lil darker on the half side. But i'm super glad it worked.
da Condividi
thanks Ross, its worked for me
da Condividi
Hi guys and thanks for the tip, I'm late to the show!! What did you mean by teardown and pressing hard where the ribbon is? Sorry bit of a newbie here! Did you need to take it apart? Love this %#*@ tablet, bit shocked to see so many instances of the same problem and very little support coming back.
da Condividi
My tablet just started having this problem (after about two and a half years). Alas, it looks like no one has discovered any fixes.
Punteggio 2
You can contact google warranty services. You will not need additional charges.
Punteggio 0
1 Commento:
There is no service centre in india bro
da Condividi
It looks like it's a bad connection (soldering job) on the screen pushing down on the stuck screen can temporarily fix it. You need to fix the screen connection.
Punteggio 0
Aggiungi la tua risposta
Kiran Reddy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 59
Tutti i Tempi: 15,540
