Salta al contenuto principale
My tablet can't pwer on
I have problem about huawei tablet
it's can't power on.
I checked the connector and the battery, no problem
what is the problem?
Questa è una buona domanda?
Punteggio 21
14 Commenti
where to buy an extra board power ic ?
da
it's can't read the puce
da
My Huawei t7 cannot power on. I have also press the reset button (volume up+power), but it's not responding. Can I solve it with PC?
da
my huawei t3 7 can power on but the screen is blank what should i do?
da
It ask me for a code.
da
Mostra altri 9 commenti
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@mohamedeln , med, Found this info. from searching through forums with similar issue as your huawei tablet t1. Hard reset. Take your sim card and memory card from the tab before the reset, battery is fully charged. Personal data from the tab, contacts, pictures, messages, apps. etc., will be deleted if it was not backed up.
Press and hold volume down key and power key for a while, your screen should turn on with option to enter recovery, follow the prompts to enter recovery mode and set the device to factory defaults. Check the link below for tutoral on reset. Good luck.
https://www.youtube.com/watch?v=7zbLOEN0...
Punteggio 14
8 Commenti:
My phone doesn't have any network
da
My tablet says that it still needs more charging, even though it doesnt
da
How am I supposed to hard reset it if my screen is still black
da
my photos are not saved in sd card they are saved in tablet, i don't want to delete those
da
i try all of the ways but nothing works please help me
da
Mostra altri 3 commenti
Aggiungi la tua risposta
med sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 39
Tutti i Tempi: 46,485
