Salta al contenuto principale
Rilasciata a marzo 2011, la Fujifilm FinePix XP20 è una fotocamera digitale punta-e-scatta da 14 MP, facile da usare, robusta e impermeabile. Disponibile nei colori blu, nero, verde, argento o arancione.
Why did my menu button stop working?
I dropped my camera and my menu button stopped working
Questa è una buona domanda?
Punteggio 1
1 Commento:
Odd messages, latch not closed, then memory error, then will not shut off or take picture
da
Aggiungi un commento
1 Risposta
The Fujifilm XP20 is supposed to withstand most impact forces from a height from around 5 ft. However, if the camera was dropped into a dirty area, the buttons may have gotten filled with dirt or dust. If this is the case, then you may need to clean out the buttons using a compressed air can, or a small brush. Water, or rubbing alcohol could work on this camera was well, since it is waterproof. If this solution does not work, then there may be a problem with circuit or motherboard of the camera. This could be self-replaced with time and knowledge of the camera, or by taking it to the nearest tech store. For more information on troubleshooting, please view our Troubleshoot page.
Punteggio 0
Aggiungi la tua risposta
Stephen Harden sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 16
Tutti i Tempi: 751
