Salta al contenuto principale
Informazioni di riparazione per la Jeep Wrangler 2007-2018, la terza generazione o generazione JK del SUV. Questa linea di veicoli fuoristrada include le versioni Sport, Sahara, Rubicon e Unlimited.
? cooling fan relay
where is the cooling fan relay switch in a 2012 jeep wrangler ?
Questa è una buona domanda?
Punteggio 0
1 Commento
There are two relays tucked together in the passenger side fender wall in the engine bay. What do they function?
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
@agent86 ,Bob, the electric cooling fan HI and LOW relays are located in the power distribution center (PDC) under the hood/engine compartment. Fuse and relay layout label affixed to the inside surface of the PDC cover for cooling fan relay identification and location. Also check out the attached link, diagnosing cooling fan problems, good article fuses,relays, fan motor,etc. Good luck.
http://www.jk-forum.com/how-tos/a/jeep-w...
Punteggio 4
1 Commento:
Not so for the 2010 JKU 3.8 SAHARA RHD
da
Aggiungi la tua risposta
Bob Garcia sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 17
Ultimi 30 giorni: 79
Tutti i Tempi: 24,910
