Salta al contenuto principale
L'HP G71t-300 è un computer portatile rilasciato da HP nell'agosto 2009. È un dispositivo consumer multiuso completo di webcam integrata, scheda grafica e sistema operativo Windows 7.
How to fix Wifi problems?
My HP G71t-300 does not detect my home Wifi. I have tried turning the device on and off already, as well as resetting my router.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
5 Risposte
Risposta più utile
Maybe your wireless drivers are out of date. You might consider plugging into ethernet temporarily and updating those drivers to see if it resolves the issue.
Punteggio 1
Check if you can connect to your home network with a 2nd laptop. If you can, then the 1st laptop has something wrong with either the wifi module itself, or the drivers for the wifi module is not installed/the wrong one. For replacing the module, see this guide. For installing the drivers, download them from the HP website using another computer, and transfer it to the 1st laptop via an external storage device.
Punteggio 1
If your laptop can detect other Wifi signals but not yours, then this is most likely an issue with your internet provider or modem and not with your laptop.
If none can be detected, however, you may need to replace the Wifi card in the device. Refer to this pagefor further information.
Punteggio 0
If your laptop detects other networks, then it may be an issue with your internet provider or your router/modem. Contact your ISP for further assistance.
If no networks can be detected, you may need to replace your wifi module.
Punteggio 0
If your laptop doesn't detect any wifi networks, the laptop's wifi connectivity may have been disabled. Check that the switch for the wifi card is on or find the key to turn on wifi.
Punteggio 0
Aggiungi la tua risposta
Jake Dykeman sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 17
Tutti i Tempi: 526
