Salta al contenuto principale
Un tablet touchscreen da 10,1" rilasciato nel 2014 da RCA Corporation.
How do I reset my tablet?
I want to reset my tablet back to the way it was when I first bought it, without all the other extra apps I installed.
Questa è una buona domanda?
Punteggio 5
3 Commenti
Has anyone else noticed that no-one gives a n answer here . . .
da
@alexisr I need help fixing my tablet
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
You can power off the tablet by holding the power button. Then press and hold the volume UP button and the power button simultaneously. This will bring you to a menu called “Android System Recovery <e3>.” Scroll to the option “wipe data/factory reset” using the volume buttons and select it using the power button. This should work.
Punteggio 7
6 Commenti:
no no no nothing works
da
I have the same problem. But tablet will not shut off with powee button
da
I can't reset mine no how no way. My grandson changed the # ive tried doing it like the video says. Nothing. Huh!!
da
Worked for me, thank you
da
No me entra el modo recovery
da
Mostra 1 altri commenti
Aggiungi la tua risposta
Grace Chung sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 21
Tutti i Tempi: 10,634
