Salta al contenuto principale
lines on the screen
i have coloured lines on the screen and a beeping noise
Questa è una buona domanda?
Punteggio 0
4 Commenti
Hi,
Do the lines on the screen appear as soon as you start the pc or only when it boots into Windows? Is there a pattern to the beeps e.g. does it go 6 beeps - pause -6 beeps pause etc?
What is the exact model number of your laptop?
da
The model is 5050-0705 and yes it does 6 beeps and then pauses
da
Yes lines appear as soon as i put the laptop on..
da
shannonmoore200 connect an external monitor and see what it shows.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Unfortunately for you the 6 beeps indicate that there is a problem with the video unit in your laptop. This usually means either a replacement motherboard or possibly a professional repair.
A repair by a reputable, professional Dell authorized service centre may be possible but it will probably be cheaper to replace the motherboard.
Punteggio 1
Aggiungi la tua risposta
shannonmoore200 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 16
Tutti i Tempi: 306
