Well stated question for a late Saturday night.
Let me address the hard drive issue first, you have several questions here and I may go to sleep before addressing them. The 2010 iMac used a Apple proprietary hard drive with special heat sensors. There are three different sensors for the three major brands of hard drives, Using the wrong drive or matching with the wrong sensor will cause the fans to run away and burn up the hard dive. OWC offers a fix for the drives without the custom sensor port, but it's about $40.
The Apple Hard drive sensors are:
Apple Part #'s
- 922-9215 - Hitachi
- 922-9216 - Seagate
- 922-9622 - Western digital
I do like the Seagate SSHD drives, I've had one failure in the last 100 drives I've installed and it was bad from the git-go.
Here's the info on the OWC solution: http://eshop.macsales.com/item/OWC/DIDIM...
RAM Upgrade:
- RAM Type: PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
- Details: Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin).
- Standard RAM: 4 GB Maximum RAM: 16 GB
Details: By default, 4 GB of RAM is installed as two 2 GB SO-DIMM modules. Two slots free.
To max out use 4X4 to get to 16.
Better is to just add 2 - 4 MB sticks and take it to 12MB. Just my opinion.
CPU Info:
The iMac "Core i5" 3.6 21.5-Inch (Mid-2010) technically is a "configure-to-order" configuration of the iMac "Core i3" 3.2 21.5-Inch (Mid-2010), The iMac "Core i5" 3.6 21.5-Inch Aluminum (Mid-2010) is powered by a dual core 3.6 GHz Intel "Core i5" I5-680 (Clarkdale) processor with a dedicated 256k level 2 cache for each core and a 4 MB shared level 3 cache. In lieu of a system bus, it has a "Direct Media Interface" (DMI) that "connects between the processor and chipset" at 2.5 GT/s.
That's all I will give you for tonight as It's past my bed time and they don't pay me for overtime. In fact they don't pay me at all, I'm just a volunteer here.
Votato
Annulla
Punteggio
13
10 Commenti
The series of your iMac: iMac11,2
da Dan
@danj hey I don't know if it is correct but there was a youtuber who put a I7 860s in the mid 2010 A1311. do you think they might have marked it wrong in the tittle or is the A1311 EMC 2389 able to support the cpu
da wolfkid
@wolfkid - Here's the specs for the Intel Core i7-860S CPU
If we compare it with the i5-680 we can see its an older chip and its TDP is 82W Vs what Apple used 73W. Other than offering 4 cores/8 threads over the 2C/4T of the i5-680 it won't offer much improvement in most apps as they are generally single threaded (the older OS and apps)
RAM and storage are still better improvements!
da Dan
@danj they both have similar ram, socket spec but the issue is will the board work with it do to the difference in power and core count.
I wish apple had a page that showed all cpu's the board could use
da wolfkid
@wolfkid - I was still writing! when you posted, refresh your screen to see the full answer.
da Dan
Mostra altri 5 commenti
