Salta al contenuto principale
The Verizon Ellipsis Jetpack MHS800L is a 4G LTE mobile WiFi hot-spot designed to be pocket sized and portable.
Why won't my device's battery charge when it is plugged in?
My device is plugged into a wall outlet via the charger. The charging cable doesn't appear to be damaged and everything else looks fine visually.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Mr Betts,
I would assume that the internal battery is damaged or old, and wont hold a charge. If the battery is in state of needing replaced then your device may not even turn on.
Punteggio 0
1 Commento:
My battery is new & I noticed this morning when plugging in to wall socket....it actually notified it will not charge while turned on. I am currently waiting for replacement unit because of recall.
da
i have just replaced my tablet with a new battery and it is only charging 5%. what is wrong?
Punteggio 0
Aggiungi la tua risposta
William Betts sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,250
