Salta al contenuto principale
Modello A1418 / Metà 2014 / Processore Core i5 da 1,4, 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
No backlight screen is dark
My iMac is A1418 2013 MF883 LM215WF3 (SD)(D1) 21.5".
I installed new screen display and have same issue
I shine a flashlight at an angle at the display and see the faint image of the desktop and icons. How do I fix the backlight?
Which is it? The CFL's or the power inverter on the iMac 21.5" 2013 model.
Thanks
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta più utile
This model uses LED's for the backlight and the power is supplied via a ribbon cable from the logic board.
Review this IFIXIT guide: iMac Intel 21.5" EMC 2805 Display Replacement. Jump to Step 20. Make sure the cable is correctly inserted.
Use a magnifier to inspect the pins of the cable and the socket as they could be damaged. If they look OK, you'll need to do a detailed inspection of the logic board as something has likely blown.
Punteggio 2
Aggiungi la tua risposta
Thuan Tran sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 16
Tutti i Tempi: 1,474
