Salta al contenuto principale
Tastiera da gaming meccanica di Cooler Master. Rilasciata con switch Cherry MX.
Replacing the Micro USB with a Mini USB
I would like to know how to replace the stock micro USB on this keyboard with a mini USB. My other keyboards use a mini USB cable and this keyboard has a micro USB; I would like to use the same cable for all my keyboards. Is this as simple as de soldering the micro USB and soldering in a new mini USB port?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
It would be easier to purchase a Mini USB Female to Micro USB Male Adapter (available on Ebay ) than to de-solder and re-solder USB ports as well as having to open a keyboard and then adapting the keyboard case to fit a bigger USB port opening.
Immagine
Punteggio 1
Aggiungi la tua risposta
kevinpattison sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 13
Tutti i Tempi: 1,658
