Salta al contenuto principale
L'APEX TM785CH è un tablet digitale da 7,85" prodotto da TMAX Technologies. Questo tablet include 16 GB di memoria e dispone di Wi-Fi integrato.
it not powering on
will not turn on. it is plugged into charger but not powering on
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Do you get an indication that it is charging when you plug the charger in?
If no:
Have you tried connecting your tablet to a working PC USB port and see if you then get a charging indication?
If yes, allow the battery to fully charge and try turning on your tablet. Your charger will need replacing.
If no, try a different USB cable and see if it you get a charging indication.
If yes, allow the battery to fully charge and try turning on your tablet, your cable will need replacing, retry your charger to see if it works with the new cable.
If no, the charging circuit and /or the battery in your tablet is faulty
If yes:
Try a hard reset.
Perform a factory hard reset by pressing and holding the volume up + volume down + power buttons. Release when the device restarts.
Punteggio 2
Aggiungi la tua risposta
first9032 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 21
Tutti i Tempi: 448
