Salta al contenuto principale
Uno smartphone prodotto da ZTE. Rilasciato nel 2013. Identificabile dal numero di modello Z992.
screen is completely black
The screen on my cellphone (ZTE model Z992) is completely black. It's charged up, I can see the green light flashing letting me know I have messages, and I can hear the tones when a text or call comes in but I can't see anything on the screen at all. I've tried taking out the battery and putting it back in, powering it off and back on, etc. I haven't done a "factory reset" yet because I don't want to lose everything that's on it. I've tried hooking it up to my computer to download pics but it's not recognized by my computer. Is it possible that the bulb for the light on the screen is broken? I can see a background light come on but nothing on the screen.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
If possible, try a different USB port, cable or even PC and see if your phone is being detected. If it is finally detected, you can try to Turn on USB Mass Storage in your phone 'blind'. By that I mean, when connected to the PC and if your digitizer is working, swipe down from the top of the phone to open USB options, then tap about 1/3rd the way down in the middle of the screen. Hopefully you will have enabled USB mass storage connection and then you will be able to use the PC to copy your data from the phone. You may have to try unplugging it and tapping it a few times in slightly different places on the screen until you get it right. Once you have got your data then try hard resetting it. Maybe a way to see if the digitizer is working before you start anything (I don't know your phone) try answering a call (I assume you tap or swipe something you would know how because you have to do it 'blind') If you can at least you know that your digitizer is working. Hopefully this may be of some help. Also tap the 'home' key before you start so that you know you are starting from the home menu.
Sorry forgot about the screen lock - if pattern you should be able to unlock by normal manner I think, if pin you could try connecting a USB keyboard via an OTG (on the go) cable suitable for your phone and typing in the numbers. then swapping back to the USB cable to the pc
Punteggio 1
Aggiungi la tua risposta
Kira Peasley sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 19
Ultimi 30 giorni: 29
Tutti i Tempi: 407
