Salta al contenuto principale
La Kodak ESP 3 è una stampante a getto d'inchiostro a colori multifunzione.
Why do I keep getting error message (Code 3524)
Message: Paper jam. Clear all paper. Press OK to continue. (Code3524)
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
6 Risposte
Risposta più utile
just where the ink holder sits move it to the side manually and you should see a sponge holder thing i think it is for cleaning the ink, beside it is a gear usually abit dirty with ink, this is the gear that has come out of sync. So get a screw driver and try to move it, then press ok try this again and again, also move the ink spongie thing up or down too and keep fiddling with these to parts until it starts to work again. If and when working go to maintenance and go through and select all the options
Punteggio 14
8 Commenti:
Thank you so much, it's working now!
It is a bit messy with ink in there. Now I just need to figure out how to get the door on top to stay up out of my way to remove the screws and clean it out on my Kodak 2150.
da Condividi
I watched a video on how to take apart the printer and did as instructed above. It is working perfectly. Thank you so much!!! Mine is a Kodak 2150 also.
da Condividi
Thank you so much!! This worked like a charm on my 2150. I was dreading spending most of the night trying to fix this problem, then I came across this post and I'm so thankful you shared this valuable information. Thanks!!
da Condividi
IT WORKED!!!!! Thanks that fixed my Kodak a three in one 2150
da Condividi
Great advice - fixed in two minutes. Any idea how to remove the print head on a Kodak ESPC310?
da Condividi
Mostra 3 altri commenti
Wow! There was a guy who had a video on YouTube, with about a half hour of instruction on how to take the machine apart to get to the area that you mentioned, but after I gave up on him (didn't have that much time or ambition), I found your answer here, and I grabbed a screwdriver. After lighting up the area with my cell phone, I found a gear that looked like it hadn't been moving, and I forced it to move, then moved another gear, just to be safe, closed up the machine -- and it was cleared of all error messages. I am SO excited! Thank you so much!
Punteggio 4
OMG! This is one of those "little problem, little hammer" solutions, but it worked. I messed with the gear near the sponge on the far left side. Had to do it twice, but it worked. I then ran clean print head, calibrate and the like and it's good as new. All gunked up inside, so I might attempt to clean all of the crap out over the weekend, but at least I'm getting work done. Funny but amazing.
Punteggio 1
This works! I’d advise have a rag to gently wipe any excess ink seen behind the cartridges and also remove any built up ink or paper dust on the adjacent areas of the inky flap. Very simple.
Thank you for the easy post.
Punteggio 0
Worked for me too. Used a tooth brush with alcohol and then some compressed air. Did it outside wearing an old shirt but it wasn’t all that messy anyway
Punteggio 0
So far tried everything on this page. Can’t get the small gear to move. My hand are black from the ink. Seems like the black was just running out of the cartridge. Was always out of black now I know why. Probably be buying a new printer, this one isn’t that old but never really liked it.
Punteggio 0
Aggiungi la tua risposta
Art Pritchett sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 12
Ultimi 30 giorni: 39
Tutti i Tempi: 11,555
