Salta al contenuto principale
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
How come my tablet won't turn on completely
I can turn on my Motorola Xoom Tablet tablet but it will only show the Red circle with the "M" on the screen. Can my tablet be fixed?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Ensure your tablet is off.
Turn on the tablet, while the tablet is showing Motorola logo, press the volume down key.
Keep pressing volume down key till "Android recovery text" shows up in top left corner
Press volume up key to place tablet in Android recovery mode
While tablet is showing Android recovery screen, press and hold the power button.
While power button is pressed, press and release volume up key
You should be prompted with: wipe data/factory reset option
Using the volume down button, scroll down to “Wipe data/factory reset”
Press power to select option
Scroll down to select “Yes, delete all user data”.
Use the power button to select.
Press the Power button to reboot.
This will cause you to lose all data photos movies music apps you have on your device. It takes it back to what it was like from new. If you dont want to lose all your data you can try removing unplugging the battery for a few days so all residual power is drained from the tablet then rebooting but this will require opening the tablet. Here's a teardown guide.
Motorola Xoom Teardown
Step 7 shows battery removal . removing the battery is not necessary just disconnecting it.
Punteggio 3
4 Commenti:
Thank you for answering my question but I tried to do as instructed and I held down the volume button for 10-15 mins and nothing ever happened.
da
this didnt work
da
did you try disconnecting the battery to reset it
da
I'm having the same problem after I hard reset and its saying supersu an os is not install
da
Aggiungi la tua risposta
Christy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,633
