Salta al contenuto principale
Il Dell Latitude E6410 è un portatile da 14" prodotto da Dell.
Bluetooth Card activation problem.
Hello,
I have Dell Latitude E6410, the Bluetooth indicator is exist on the top of F1 key, My WIFI is working , so do I have WAN card on my laptop?. In such a case why my Bluetooth is not working?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
In System Setup (BIOS) there is an area called Wireless where you can check that your Bluetooth is enabled.
( to enter system setup press F2 when you first turn on your laptop)
There are two options displayed.
1. Wireless switch : which allows you to determine the wireless devices that will be controlled by the wireless switch: WWAN, WLAN, and Bluetooth.
2. Wireless devices : which allows you to enable or disable the following wireless devices: WWAN, WLAN, and Bluetooth.
Here is a link to the E6410 service manual which describes the System Setup (BIOS) settings. http://downloads.dell.com/Manuals/all-pr...
Punteggio 2
Aggiungi la tua risposta
haassir sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 17
Ultimi 30 giorni: 24
Tutti i Tempi: 1,556
