Salta al contenuto principale
Rilasciato a settembre 2013, identificato dal numero di modello T100T. Dispositivo portatile 2-in-1 con processore Quad core Intel® Atom™ e 2 GB di RAM.
How to reset BIOS?
In Asus T100 is there BIOS battery?
Or do I just remove battery for several minutes?
Or maybe anyone have Rescue Password for 2012/01/01?
Questa è una buona domanda?
Punteggio 23
56 Commenti
Did you found a rescue password for 2012/01/01??? Please, let me know.
da Condividi
The ASUS rescue password for 2012/01/01 is ABLDABLA (make sure you use caps).
da Condividi
please password' not working abldabla
da Condividi
14/01/2016 Please
da Condividi
2012/08/10 please
da Condividi
Mostra 51 altri commenti
Aggiungi un commento
8 Risposte
Soluzione prescelta
Nvm, I guessed password.
It was "asdfmovie" xDDD
But thanks for trying.
Punteggio 4
Risposta più utile
Try this rescue password: ABLDABLA
Let me know if it works :-)
Punteggio 11
24 Commenti:
Haha LOVE ASDF Movie! Nice password ;-)
da Condividi
This password don´t work for me. Please, I need a password for 2012/01/01 that works!
da Condividi
please help i have the same problem when i start my Asus nx500j laptop it asks for bios password
da Condividi
I need a password for 2016/02/16 or 2016/02/17. Help please!
da Condividi
Why would anybody so dumb as to put a password on the BIOS?
da Condividi
Mostra 19 altri commenti
Hi Idav2k9,
Because it prevents other people from changing the configuration of your PC, if you happen to leave it unattended for a short time, like if you are in a library for instance.
There are some people who think that it is funny to do this.
Once bitten......
Punteggio 2
1 Commento:
Pls all the passwords are not working for me,pls help me
da Condividi
Assuming you are locked out of the OS as well and can not simply use a third party tool or change your date to use a recovery password, then use this method. It is actually easier than hassling with all that IMO.
== Using a Backdoor Password ==
Here is a list of American Megatrends Inc. backdoors. A password in BIOS which always works irrespective of what password you have set in BIOS. Its a master password which is used for testing and troubleshooting purposes.
A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
This will allow you to bypass the password.
For most systems you can get the list for your use by inputting the incorrect password 3 times. You should see a message that reads "System Disabled" followed by a number. Go to BIOS-PW.org and input that number to get the password list for all manufacturers that match that checksum you entered. These will always work as long as the password you put in matches the checksum the system gave you, because that will be the same checksum generated by your password.
Immagine
Also, don’t worry about the system disabled message because it’s just a scare tactic. All you have to do is turn off the computer and turn it back on and you’ll be able to enter the BIOS password again without any issue. This method works for almost any computer so instead of burying it here I am going to check to see if there is a guide write up for it, and if not create one for easier access.
Punteggio 2
1 Commento:
It doesn't work, never apearse the message of system disables message
da Condividi
Go to Windows and set dat to 2002/1/2 (US date format)
reboot and when it promt for password hit alt+r for recovery password mode
type in pass ALAA4ABA
Punteggio 1
2 Commenti:
I need a Bios rescue for Asus Tablet R+Alt = 2016/03/25.
Could you please give me the rescue password?
da Condividi
It's for my Asus t100ta Transformer tablet (so, I can't get too the closing battery
da Condividi
When I hit alt+r, my bios date keeps changing. How do I find the right password?
Punteggio 0
1 Commento:
need rescue date for my Asus X441N laptop
da Condividi
I and thanks for help, but on T100H with 2012/01/01 don’t work ? Why ???
Don’t work with caps, without caps, on screen, on keyboard, on external keyboard…
Please help
Punteggio 0
3 Commenti:
I try ABLDABLA / qwerty and azerty (I'm French)
da Condividi
could you solve it?
da Condividi
Please tell me if you ever figured out the bios password to T100h I'm really needing it
da Condividi
I have this asus n3700-a/k20ce model and there is no jumper to clear cmos. Pressing alt+r wont work. I have taken the battery out for more than 24hours even tried up to 2 days. Shorted the negative and positive of the battery. Even stripping all the cables out but no luck at all. This is frustrating. Even asus couldnt give a good solution. Maybe next time before u buy an asus mobo.. better check whether it havr a cmos reset function or not.
Punteggio 0
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 61
Tutti i Tempi: 42,155
