Salta al contenuto principale
La prima Legacy fu disponibile presso le concessionarie giapponesi il 1° febbraio 1989, con una distribuzione globale iniziata nel 1990.
Front left Headlight dull
Subaru 94 rs legacy. front drivers lights are dull I've taken the bulbs out of the case and turned them on but the drivers side light is dull and orange on hi lo and dip what could it be. Do you know where the earth is for the drivers side headlights?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
I would test for a bad ground by putting a jumper wire between ground on the vehicle, and the ground for the bulb, and seeing if that increased the brightness. I believe your car uses an H4 type bulb with a 3 prong base. If you hold the bulb so you are viewing it from the back, with the middle prong at the top, the prong on the left is ground, the middle is low, and the right is high beam.
Punteggio 3
1 Commento:
Bulb might be dying. +
da
Aggiungi la tua risposta
brandon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 33
Tutti i Tempi: 3,028
