Salta al contenuto principale
Il Kindle Touch (D01200) è la quarta generazione di eReader prodotti da Amazon. È dotato di connettività Wi-Fi o Wi-Fi/3G; tutti i caricamenti vengono effettuati tramite cavo USB. Dispone di 4 GB di spazio di archiviazione e due mesi di autonomia della batteria.
Home/Menu button does not work
The Home/Menu button of my Kindle Touch does not work. I can hear and feel the click, but it does nothing.
Is there a way to fix it?
Questa è una buona domanda?
Punteggio 9
Aggiungi un commento
3 Risposte
Risposta più utile
Here’s what I did to reactivate my Home button. I surmised there was a buildup of crud in the switch mechanism that needed to be cleaned out. I chose 91% isopropyl alcohol because it was a high grade solvent that would mobilize the crud without leaving a residue or attacking the plastic. Don’t use plain rubbing alcohol because it has oils in the alcohol to facilitate “rubbing.”
1) Turn the unit off.
2) Take a napkin soaked in IPA and daub the raised portions, allowing a little to slip into the slots.
3) Before the IPA evaporates (and it will evaporate quickly!), work the button repeatedly.
4) Repeat as needed
Each cleaning cycle, things got better and after three, operation was great - took 5 minutes for the whole thing!
Punteggio 7
6 Commenti:
Yes! Totally worked as you described. Let's hope this solution lasts.
da Condividi
Eric - Thanks for the tip. I actually pried off the front cover (not as easy as some video clips show) and cleaned the actual micro button with some iso p alcohol. Cleaned built up gunk (10 yr old Kindle) and now it WORKS. Thanks again.
da Condividi
Thank you so much! I love my Kindle Touch 4Gen so much and will be so sad the day it truly stops working and I need to "upgrade" - I was so happy to find this simple solution that keeps it going for a little longer!
da Condividi
Thanks! So simple and so effective!
da Condividi
Yay!,,That worked! Thanks!! : ))
da Condividi
Mostra 1 altri commenti
Is the 'new home button' attached to the bezel, or to the motherboard in this case? And if it's just a shorted wire, what is involved with this repair?
Punteggio 1
You might have to just get a new home button or check and make sure that the connector is securely plugged into the logic board as it may have jarred loose, either that or a shorted home button wire.
Punteggio 0
Aggiungi la tua risposta
Fernando Sancho sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 55
Tutti i Tempi: 16,381
