The X button Doesn't Work.
The X button (not the guide button) on my controller does not work; however, every other button does work. Which motherboard do I need to replace to fix this problem?
Questa è una buona domanda?
Have you tried cleaning the membrane (the rubber thingy with the buttons on it) and the motherboard?
Preparati per le riparazioni future
Acquista tuttiTake a screwdriver and press the button as much as you can i did it and it worked hope this helps
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 12,861
7 Commenti
Hello, Has anyone gotten any answers on this matter? As of now this is part of an issue I am having with my controller. Should I call XBox for assistance?
da Christina
same thing has happened to me aswel… i was not bothered to much i just rerouted X to the bottom back paddle.. now the kids have broken the shells so gonna re do all the parts.. I really want to know aswell if the X button is a hardware or software problem
da brandyn4work
It also happened with my controller from the xbox one s. Got it connected to the iPad Air and played Genshin impact. Suddenly the X button stoppend working. Connected it to my xbox and it si somehow overly sensitiv. instead of moving one tile it moves two. Updating the controller firmware did not do anything. Problem is the same. I can not point out if it is a hardware or a software problem. I only know firmware update does not cure the controller.
da Anton S
mine is the Model 1708 so it seems to be a general issue
da Anton S
the same thing happened to me but im still trying to figure it out
da Will Herrington
Mostra altri 2 commenti
