Salta al contenuto principale
Possible to replace the CPU or welded?
I am thinking about buying a low spec Pavillion 11 x360 and then upgrading the specs if possible. However, a welded CPU would be problematic. Could you please tell me whether or not it's welded? Thanks
Questa è una buona domanda?
Punteggio 1
1 Commento:
if it is or is'nt anything is possible just put your mind to it
da
Aggiungi un commento
1 Risposta
These systems have an integrated SOC that are integrated into the systemboard as indicated by the Maintenance and Service Guide spare part numbers.
While it may be possible to remove the SOC and replace it with another, the equipment required to this may be specialized for that purpose and upgrading the board itself may be more cost-effective.
Punteggio 0
Aggiungi la tua risposta
Sam Choi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 1,621
