I'm having problems with error code 8002F1F0
I tried updating my system, and it failed multiple times before giving me this error code. (8002F1F0) I can't even get into safe mode. Help!
Questa è una buona domanda?
Hey Cameron, I have two options you can try (try both):
Option 1
Try to download the update from Sony's website and put it on a flash drive and install via USB.
Option 2
As the update will start pull out the HDD (litte plastic cover on bottom of the PS3 and one screw). Then it should run to 99% and stop without any messages. Then, unplug the power to restart the system. At the next restart it will run to about 45% and then jump to 100%.
-Let me know how it goes.
-Please accept this as the answer if it answers your question.
Do i put the hard drive back in when i unplug it
OMG dude I just Get my rpoblem SOlved (srry about my english), My console always give me error at 66% i restart it al most 20 times Them when it was close to 66% i push the power button and the sistem get fix .. i can't belieave it jajaja
Hi, my ps3 has now reached 99% (finally!). Based on your suggestion above, do I unplug the system and plug it back in with the HDD back in the system or not for it to jump from 45% to 100% on the next restart?
At The Next Do We Have Put HDD inside again, because I have tried inserting but still update get stuck at 99%. Please request for help !
Stuck here too... get to 99%, unplugged and tried restarting without HD but it wont start download due to missing component.. if i reinsert it gets stuck in same 66%, tried both ways, and already switched out the lithium battery in the MB but still no luck. I really think its the whole BT issue since i know my controllers stopped working without being connected directly via usb. Please help someone???
We need help with a code for playstation 3
8002F1F0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 8,273
