Salta al contenuto principale
L'HTC Desire 816 presenta un display da 5,5 pollici con risoluzione 1280x720, fotocamera posteriore da 13 MP e HTC BoomSound.
SD Card removed unexpectedly
Hi,
I use a htc desire 816g since feb 2015.My phone worked very well from Feb till May.
One afternoon, i was using both WI-FI and mobile data and was quickly shifting from one to the other to test a process speed. Suddenly my phone got hanged.
I switched it off to restart but it did not start till 5-7 minutes. When I opened the Flip cover, it took a minute and then turned on.
Since then whenever I turn off my mobile data or WI-FI, I get a modification "SD Card Unmounted Unexpectedly".
I gave it to the store where I bought it, he suggested to reboot it. So he did and gave it back to me. Still I am getting this problem.
Please help, I want my phone to work like it use to before. W#waiting for a fruitful reply.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
According to description the fault coming from your SD card. buy a new class 10 SD and you may solve the intermittent fault.
Punteggio 0
From what you are saying in your statement the issue is within the SD card it self. I would suggest trying to save any data possible in the SD card and with the purchase of the new card transfer the data. If that is not possible, Just replace the old SD card with a new. I would suggest purchasing a SanDisk SD card or a Samsung evo+.
Punteggio 0
Aggiungi la tua risposta
Raj Laxmi Behera sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 11
Tutti i Tempi: 2,075
