Salta al contenuto principale
Il Jawbone MINI JAMBOX è un altoparlante Bluetooth piccolo e portatile che offre un suono di qualità in un formato compatto.
Music not playing through bluetooth?
My phone is paired with the MINI JAMBOX over bluetooth, but I cannot play music. However, I can play music over the auxiliary cord, but not over bluetooth. Whats going wrong?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
6 Risposte
Risposta più utile
Have you tried a bluetooth reset or a software update? Here is a link to the soft reset: Jambox Reset and here is a link to the software update mytalk.jawbone.com
Punteggio 3
Another common issue with the JAMBOX MINI is "phantom auxiliary" connection. Your JAMBOX thinks it is connected over auxiliary, so you tries to play audio over that connection instead. Check if there is any blockage in your auxiliary port and take a look at our bluetooth troubleshooting page here. If you think this might be the issue, you should follow our USB / auxiliary port replacement guide here.
Punteggio 0
Be sure that the audio cable that you can use to physically connect your phone to the audio jack of the JAMBOX Mini is not plugged into the JAMBOX Mini. When the audio cable is plugged into the JAMBOX Mini's jack, it won't play via Bluetooth. Once you unplug that jack, the JAMBOX Mini will play the Bluetooth audio.
Punteggio 0
I had the same problem, just make sure NO CABLES are connected to your JamBox at all
Punteggio 0
I have my Bluetooth connected to my subwoofer and it's saying it's connected at the top but I don't hear any music and I'm not really good and connecting
Punteggio 0
1 Commento:
How can I connect my Bluetooth and hear the song at the same time so I can hear it through my radio.
da
My new jawbone jawbox didn't work, cause I can't hear the sounds on my speaker
Punteggio 0
Aggiungi la tua risposta
Noah Sadler sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 27,164
