Salta al contenuto principale
Numero di modello: 7DTB39 / tablet da 8 gigabyte / schermo da 7", 1024 X 600
Forgot screen unlock pattern
Forgot pattern to unlock screen.
Questa è una buona domanda?
Punteggio 4
1 Commento:
The tablet is locked .wont even let me turn power off
da Condividi
Aggiungi un commento
1 Risposta
Is there a forgot password option on the lock screen? Sometimes you can use your Google account to reset the password.
If not, you can factory reset your device using the following steps:
  1. Power off your device, and hold the volume down key and the power/lock key simultaneously for a few seconds.
  2. In recovery, there will be a “wipe data/factory reset” option you can select. Use the volume keys to navigate and the power button to select a menu option. This will wipe all data on the device!
Hope it helps!
Punteggio 0
Aggiungi la tua risposta
richbeja357 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 16
Tutti i Tempi: 798
